Archive
How to get results of multiple searches enabled in a website? Is this correct? I'm not sure. But when I go with this,But it only returns the results with the order of entry.
Please help?
Read moreI know this is old but the system is using Oracle Business Intelligence 10g. when we click on a worksheet it takes so much time to process the query.
Read moreIs there any possible way of not allowing changes with the primary key? Something called ON UPDATE RESTRICT?
Read moreI want to get the total number of records retained without DUPLICATE ones in my database. IS this correct?
Read more
Hi there, it's not easy to find a hardware routing solution that would allow to leave my MAC filtering open. But I want to allow for authentication ( username and password )before it allows connection to my network? How is this possible?
Read moreI've heard rumors that some service providers can see unencrypted VPN traffic of their customers. Now I'm a bit scared on my end. Is this true?
Read moreI'm working for a network company and it has CISCO devices used in the network. So it has complied with CISCO standards. Now I need to merge with a network which uses IEEE.6 standard. Is it possible? Which standard should I use?
Read more
Hi, most of my clients are home based. So may I know whether I can use VPN over a peer-to-peer network within my home?
Read moreHi there, Some of my computers are with windows XP, and the rest are with Windows 7.
When using windows XP I am unable to find my folders on the server even, but my VPN tunnel is all up and running.
I'm using a wireless connection.
Can you help?
Read moreI want to create a database of with classes and some coding and with a simple intelligence. How do I choose the best database management system software?
Read more
