Archive
I am using Mozilla Firefox like forever but I have not faced such a problem yet. Firefox is not starting, however I can see the application opened in the task manager. I do not what to do. I have tried closing the application with task manager and restarting but it remains the same. I have also tried restarting the PC but that did not work either. Please help me providing ideas about how to solve this problem.
Bruce Norway
Hello everyone,
I have been into some serious problem while installing remote agent on my computer.
I have Leopard OS currently running on my system, and whenever I try to install this it leads to the following installation failed error.
I even restarted my computer, but this does not help.
Please help!
Hello there!
Is there someone who can help me to install Tivoli storage driver on my computer.
I get the following error during the driver installation wizard.
I looked up the error log file in windows folder which shows the following messages:
ERROR: RETURN UpdateDriverForPlugAndPlayDevices. (Error code 0x2: The system cannot find the file specified.)
ERROR: Installation failed. (Error code 0x2: The system cannot find the file specified.)
ERROR: PnP Install failed. (Error code 0x2: The system cannot find the file specified.)
Device Driver Installation Wizard
Cannot Complete the Device Driver Installation Wizard
Errors were encountered while installing...
Can anyone give me a hand in resolving this issue?
There are three different options available under the advanced option tab to install new components for a server.
These include very easy steps all you have do is just follow the on-screen instructions and proceed with the installation after entering the correct credentials when prompted by the installer.
When using the advanced tab the components are installed without having any problem in the functionality if SQL server embedded edition that is already installed.
Just click Next whenever prompted and installation wizard will do the job for you. If there are any errors during...
Read moreHello,
I have an Apple iPhone and I am having some trouble dealing with different features on it. It will be real easy for me if there is a file manager for that. I would refer the best one in the market.
I would also like other methods by which I will be able to see different application installed, different file types etc.
Please help me with this problem.
Karlos Hilton
Read moreHello,
I am trying to install Qt SDK, I downloaded the iso image and all I know is to mount that iso image and install the software.
But I don’t know what is happening to me as after very lengthy package installation steps I get this installation failed error.
What should I do?
Install Qt SDK
There were errors with the installation. You may want to try installing again.
The installation failed.
The installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
There has been a recent problem with Microsoft word 2007 in my pc. Earlier I used to open it with all programs-->Microsoft office
Microsoft office word 2007 method. But now I do not see the Microsoft word 2007 in the Microsoft office menu. I tried to fix it but I am out of ideas. I want the Microsoft word back in the Microsoft office menu.
Please someone give me suggestion about how to bring it back.
Leo Kingston
Read moreHello experts,
Please help me find the solution for the error I get when installing BitDefender 2010 on my 64-bit windows 7. I even tried installing it on Windows Vista but the same following error occurs during the installation:
BitDefender Internet Security 2010
Extracting file failed. It is most likely caused by low memory (low disk
Space for swapping file) or corrupted Cabinet file.
I have to use about four to five browsers at a time for my job and all the browsers has to be quick. So far all the browsers were working properly, however recently the thunder bird browsers has gotten slow which is affecting my work greatly.
If this problem is not solved quickly then there will be some serious problem.
Vincd Milano
Read more
Hi experts!
I don’t know what to do now, please help!
I tried to install this thing on my computer and I followed all the steps described to install this but I get an “Installation Failed” error. Following is screen shot describing what I have done and what the error is:
