Archive
Hi everyone, please consider the following code segment and tell me what is the values z after executing the code segment
<script language="JavaScript" type="text/JavaScript">
x = 800;
y = 45;
x += 60;
y %= 1.5;
z = x + y;
</script>
I have been playing fallout game in my pc for quite a while and now I need to uninstall it. I have tried to uninstall it but it is not working. I have tried to uninstall it manually but that did not workout either. Please tell me what should I do. For your information I am using windows 7 operating system.
John Parker
Hi friends , why use of surrogate key instead of using primary key , can anyone explain me with some simple examples
Read more
Hi guys , I want to play playstation games on my pc , can anyone please give me a good PS-emulator to do this?
Thank you
Can anyone please explain to me what is Primary key and what is Foreign Key and the purpose of using this type of keys for databases
Read moreHello All!
I am trying to install OpenOffice.org on my Windows Vista.
After so many steps involved just to allow the installer to start installing this thing on my computer, I saw the following error just after the installation finished:
Error
Installer: Wrapper.CreateFile failed with error 123: The filename, directory name, or volume label syntax is incorrect.
Read more
Hi guys , I need some simple explanation about TCP/IP
“Wikipedia says : The TCP/IP model (Transmission Control Protocol/Internet Protocol) is a descriptive framework for the Internet Protocol Suite of computer network protocols“
you know,that explanation is too complicated for me to understand the concept,please can anyone explain it in simple form
Hi guys,
Can anyone please explain me what is Database normalization and why it's important.
Need answers quickly.
Read moreHello pals!
Does anyone of you know the method to install device driver for my HSDPA card by ZTE on Leopard OS.
It worked just fine on Microsoft windows but I find myself in no luck installing it on Leopard.
I even tried to download the driver setup from company website but nothing helped.
If anyone have a solution please tell me. The following error occurs on the screen:
Install INDOSATM2
Installation had errors
The installation failed.
The following install step failed: run preflight script for INDOSATM2. Contact the software manufacturer for assistance.
Read more
Hi guys , is there any software or method to convert audio files to text , because I have number of audio tutorials which need to convert into printable format , can anyone please help me
Thank you
Read more
