Archive
Windows Home Error 1620 is actually the consequence of compilation of issues together with the Windows Tech Package.
The mistake will likely be the consequence of not having the best data files as well as adjustments that the pc requires to control this installing package.
This could possibly be attributable to this system’s installer becoming corrupted, or perhaps Windows Home being unable to operate the program correctly. Either way, you'll need to make sure that the particular set u is actually valid, and that your machine has the ability to run the program.
Hello, I’ve got a mini net book that came with Roxio Backon Track (version 2007). I have used it to maintain backups, but unfortunately the netbook was damaged on 19-01-2010. At this point my business is looking to recover the information on the system.
It seems like it still manages to boot, but has errors that make it impossible to replicate the information on it. It is not recognizing any external drives. I've found this website and am looking for any help that may be offered. Is there anything I can do to recover the data?
The netbook itself had windows XP home edition sp3 32...
Read moreYesterday I used Firefox then it became unresponsive 30 minutes later. I closed the program from the task manager.
And now I can't open it. I have reinstalled the program, but nothing changed.
I need solved.
Thank You.
Read moreEach time I try to start my personal copy of AutoCad I receive an error. There is no indication of what caused the error. Can anyone tell me the best way to correct this particular problem?
AutoCAD
Yesterday I bought a new laptop type: Asus a43sa
I tried it at home, some keyboard buttons didn't execute correctly. When I pressed "A", it showed right click command.
Buttons with same error problem: A, S, X, Shift. I have re-installed it, but nothing changed.
Anyone know what's wrong with this laptop?
Read moreI installed Windows 7 Pro 64 bit. The install and computer worked very well, but I eventually ran into a problem a week ago. I've tried uninstalling and re-setting up the software, but I can't seem to manage to get onto the web. It is really important that I have this setup since I will be traveling throughout South Africa where Vodafone has service.
I've tried talking with technical support, but the gentleman who has been helping me has not been as successful in getting my issue resolved.
During the install, the laptop didn't recognize the device. He told me to...
Read moreLast year I went through the process of starting incremental backups on my photos from the Acronis Accurate Photo Home. It was an extremely slow process, but it eventually finished. This year, however, I found out that there is an error in the backup. Every time I try to restore I get the following error:
Failed to open data stream
More information about this error and solutions may be available online in the Acronis Knowledge Base.
To Access the online recourse manually, enter the event code at : https://kb.acronis.com/errorcode/
Event code: 0x000803E9
Error code: 0x000B03E9
Does anybody have any suggestions?
Read moreWhen working with computer system-web page PC-link software version 2.0.0.0.7, the "Activate operate" or perhaps the "Software package update" gives a system error stating that the server information is invalid.
How can this be fixed?
Hello buddies,
After I tried using the LaCie set-up assistant, but I keep getting this error message stating that PowerPC applications are no longer supported.
Is there any way around this?
You can’t open the application LaCie Setup Assistant because PowerPC applications are no longer supported.
OK
I just now installed SKY X Professional edition. When I connect to the CCDAP5 application and try setting it up I get the message.
I can't seem to get past this error.
Please help!
Link to software error, The SkyXAdapter.StarChart 1: COLeException Type
mismatch.
(800200005) SCODE: 80020005.
OK
Read more
