Archive
Hello. When I click on the shortcut for tweetmypc I get the following error: "TweetMyPC has stopped working"error. The Problem details include:
Description: Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: tweetmypc.exe
Problem Signature 02: 2.0.0.0
Problem Signature 03: 4a257f55
Problem Signature 04: TweetMyPC
Problem Signature 05: 2.0.0.0
Problem Signature 06: 4a257f55
Problem Signature 07: 10
Problem Signature 08: ef
Problem Signature 09: System.InvalidOperationException
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
I tested the permission/read-only/security allow from given tips but didn’t found any change. I am on Vista x86.
Any help would be appreciated. I...
Hi. I'm facing a problem while setting up relaying on Exchange 2010.
Yes, I use an intranet page written in asp .net to send an email to a group of addresses stored in an access database. The problems emerged when the page wants to send emails outside of the domain. Sending Emails within the domain or sending internally is ok..
The error message is:
Server Error in '/' Application
Mailbox unavailable. The server response was: 5.7.1 Unable to relay
In EMC I've made a receive connector and set the network tab to receive mail from the local machine IP...
Read moreMy PC was so slow and therefore, I wanted to format it and reinstall Windows XP. I booted the PC from its DVD rom and while trying to copy files, it stops and does not go further.
I tried different xp cds and distinct CD drives, but the result is the same. Again, I connected the hard disk to another PC and tried to install XP, then everything went well. I could successfully install XP.
When I reconnected the hard disk to original PC, when loading XP, it gives the blue screen. Kindly tell me a solution.
Please help.
Thanks
Read moreMy Hard disc C, currently has been running with a very low space (2.55 gb to be specific), and this is really making my computer run very slow and still i cannot be able to store more due to space wise. my other partitioned hard drive has more space (47.98 gb free space), all i want is to reduce the space on D: and increase the space on C:. how do it.
Martin
Read moreI am using Total Video Converter and I boot registry code. It's working good but while I'm try to convert a .VOB movie file to .3gp on its default setting and click to start convert every time it's give me a error message called "Error while opening codec for output stream - #0.0". How can I solve this type of problem and how to convert .VOB to .3gp file?
Error while opening codec for output stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
OK
Read moreMy machine has Windows XP.
The welcome screen, i.e.. the black screen comes but the blue bars goes on forever and its stuck.
Read moreI have a site in wordpress and I want to transfer it to another server. Any good and recommended servers?
Read more
I uploaded a .wmv file (a flash cs3) and I want it to stop/pause when movie buttons are pressed.
HTML coding for this please?
Thanks in advance
Read moreI just downloaded the Dreamweaver 5.5 and I'm confused with it. I went to the tutorial site but I don't get them. Can you please key-in a good tutorial site?
Read more
I heard today that one of my friends talking where we can create HTML code within PHP.
Is this possible?
Read more
