Archive
When I am trying to connect to a SQLite3 db on the Data Sources I get the following error:
I have checked that the db file has no errors via Firefox SQL Lite Manager.
I really need to find a solution for this problem.
Please help me.
Error:
3 of 3 tables were loaded.
The following errors were encountered:
Table: SCHEMA_MIGRATIONS java.sql.SQLException: not yet implemented at org.sqlite.MetaData.getImportedKeys(MetaData.java:503)
Table: SQLITE_SEQUENCE java.sql.SQLException: not yet implemented at org.sqlite.MetaData.getImportedKeys(MetaData.java:503)
Table: USERS java.sql.SQLException: not yet implemented at org.sqlite.MetaData.getImportedKeys(MetaData.java:503)
Read moreHi there,
I can't figure out why the folders and files are not visible. When I check the hard disks the capacity is still the same so I think the files are still there but I can't view it. Is this some kind of a virus
Read moreHow can download images from facebook content if there is no download option and those picture is protected from my id ?
Read moreHello all,
I’m getting iTunes error "iTunes was unable to load provider data from Sync Services. Reconnect or try again later." and unable to make sync to my iPhone Please help me with right direction.
Help would be appreciated greatly.
Read moreHello guys,
I was attempting to set up the Team viewer’s most recent version on a Windows 7 Pc, but when the install was finished, I keep receiving the following error: Install Service error CService Configuration: Installservice (): create service failed Error Code=1072 Please help. Thanks.
Read moreHi all,
When I am installing codec pack 780 full versions, I find "an error occurred while copying file. The source file is corrupted" message .I need to understand about this error and the way to solve this and install the software. Thanks in advance.
Read more
Hi guys,
I’m unable to login to Windows Live Messenger. I receive an error message code 80048820 and already I have used "regsvr32 softpub.dll".
Then I have made reinstalling of Windows Messenger and my firewall, also test that there are no alternative settings on my windows explorer.
Need your help.
Thanks in advance.
