Archive
Hello experts,
I am receiving the following error message.
I need to solve it.
Please help.
Thanks in advance.
Error:
php.exe - Unable To Locate Component
This application has failed to start because MSVCR71.dll was not
found. Re-installing the application may fix the problem.
        OK
Read more
Many users have well-known that IE5 may create a confusing, unsuitable and completely scary error message. The error message is:
Error:
Internet Explorer cannot open the Internet site Operation aborted
Need a solution. What should I do?
Read more
Hi experts
Just I have downloaded and installed the BlackBerry Tablet OS SDK for Adobe AIR.  Have anyone installed it? When I try to see how it seems, I just find an error. For this reason I also downloaded the OS SDK but the following error message pops up:
Error:
Incorrect SDK Detected
Incorrect AIR® SDK selected.Please browse to https://www.adobe.com/devnet/air/air-sdk-download.html to get the Adobe® AIR® SDK 2.5
Need your help. Thanks.
Read more
After many days I just installed windows XP in my computer.
It was a hasty installation.
When I installed my required software there were no problem at all.
As I started to browse the pages that starts with "https" , I can not go through that particular page but it showing SSL Certificate Error.
How can I fix the problem now.
Read more
Hi all.
Currently, BlackBerry Desktop Manager 5.0.1 does not support Microsoft Outlook 2010 64-bit version for mailbox connectivity and synchronization of organizer data such as Calendar, Contacts, Tasks, and Memos.
The next release of the BlackBerry Desktop Manager provides support for Microsoft Outlook 2010 32-bit version only. This release is targeted for August 2010. Support for Microsoft Outlook 2010 64-bit version will be available in 2011.”
What is the meaning of this?
Can anyone help me? Thanks in advance
Error:
Microsoft Outlook Connector Error
No available message stores.
Read more
Hello
If I tried to select any option, I got this 0x80040fb3 error message:
Intellisync Error encountered. Error code -0x80040fb3. Check documentation.
Please help me. I need your help.
Thanks a lot.
Read more
Hello experts,
I have faced the following errors and I have no idea what does the error mean. Please give me a solution.
Thanks in advance
Windows - System Error
Unknown Hard Error
Ok
Read more
Hi
I use windows media player version 11 on my PC. I have installed Mappoint 2004 without any troubles and the program runs very well. But without uninstalling Mappoint 2004, I try to install 2006. In the mid time of the install process an error message occurs that seems like this
Windows Media Player 10
This version of Windows Media Technologies is incompatible with this version of Windows. For more information, view the information at the Microsoft web site.
Need to solve this error. Thanks.
Read more
 Hi
The first facilitate Advanced Installer presents is during its advanced Native Java Launcher.
When opening a Java product packaged by Advanced Installer, the launcher will look for a proper JRE installation. If nothing is found, the following error message appears
Error:
JRE Not Found
Missing JRE
The Java Runtime Environment (JRE) was not found. Please download and install a JRE (latest version) from:       https://www.java.com/en/
If you have a JRE installed you can browse for it below:
What should I do? Need a solution to solve this.
Thanks in advance.
Read more
I am getting the following error message when I try to install the iPPOTV (see figure below):
Error
Assertion failed!
Program:C:program [email protected]
File:player.cpp
Line:16
Expression:m_hModel
For information on how your program can cause an assertion failure,see the Visual C++ documentation on asserts.
Need your suggestion to fix it. Please help.
Thanks a lot.
Read more
