Archive
I am using two HP All-in-One Printers. Now what I want to do is to print same document on two printers at the same time. How can I command the printers to do that? Please help.
Read more
I am using D-Link switch that connects my local network to my ISP with ZTE MF612 Wireless Router. But I was unable to get a internet connection when using the switch even though I have a firm connection. How can I be able to fix this?
Read more
When should i use the recovery console and how do i install it when needed?
Read more
How i can create Password in USB port in windows 7
Read more
I used Windows 2003 and Internet Security and Acceleration Server for blocking unwanted websites but a client in Windows 7 could not get an internet connection.
Can someone please give me a step by step procedure on how to set up the internet correctly?
Read more
Why should you enforce the Use of Ctrl+Alt+Del whenever  you want to log in ?
Read more
What are the default NTFS permissions for most files and folders and who can them?
Read more
I have made a database that consists of product codes with their corresponding prices. I encoded the product codes and then tried to update the database but when running the MDF file, it is still showing the updated product codes. Does anyone knows how to avoid this permanently?
Read more
When you set Permissions on a folder, what happens to the files and sub folders?
Read more
What happens when a User receives permissions in their own right and as member of one or more groups?
Read more
