Archive
What would I need if I want a system that would make lights and sounds in my cafe controlled by a single computer? Do i need another computer for security cameras?
Read morehow to insert the word document or upload the resume in the column of table having the clob data type using the vaadin framework?
Read moreIs it safe to Format my mobile firmware? And is it possible to replace OS?
Read more
I am wondering if there are criteria that I can use as basis to know that the application works in versions 2.2 and 3.0 of Android OS?
Like for example,
- It can be installed
- The response time is fast
- It supports the screen resolution...
Please guide me.
Thanks
Read moreWhat is the best software to record audio? I'm going to do a video narration, is windows' sound recorder ok?
Read moreWhen I download PDFs, everytime I open them only lots of squares appear. I tried changing language and all recommended actions in help menu, nothing worked.
Read moreHello
I have just finished set-up my computer.I turned the computer on and everything runs, the fans lights etc.
But there is no display.
I know its not the ram because I just replaced it with some that I know it works.
Could it be the video card. I am really pissed that the thing isn't working.
Help me please,
Thanks
Read moreWhat's wrong with my phone? It detects wi-fi signal but wouldn't connect. It's not a password issue. Can you help me?
Read more
