Archive
How do I limit the upload available on my computer? And how would I also know the limit of it?
Read moreHome page of any antivirus site not opening in any browser while all other sites are working fine.
When the search page with antivirus key words not loading
Read moreWould you give me an idea or tips on how to build a website that may gain attention to more audience?
Read moreHow do I access Remote desktop connection? Does it have to be more than one computer? Thank you :)
Read more
When i run the application as android application. An error encountered
“The application has stopped unexpectedly. Please try again."
Read moreHello,
When I try to connect to computers in my wireless LAN I get this message.
"Windows cannot access \(computer name).
I can connect to the internet. I run Windows 7 Ultimate 64bit.
All other computers are Windows XP.
Windows Cannot Access \SABINA- PC
Check the spelling of the name. Otherwise there might be a problem with your network. To
Try to identify and resolve problems, click Diagnose.
Thank you
Read moreWhat is the function of task manager in the windows operating system?
I know some of the functions but I am sure that
I don't know all of them.
I heard that it can perform several of functions.
Please tell about its functions and capability.
Read moreI am currently using windows 7 but I have heard that if Windows 8 comes with a virus protection program. Is it true and if yes, how effective is it?
Read moreI use windows XP as my operating system and I wanted to change icons of this windows from its default to that.
I customize but I don't know how to do it.
Will you please explain the process to change it?
Read moreI use windows 7 64 bit version but now I want to convert from 64 bit to 32 bit. How can I do so? Do I have to reinstall the
windows to downgrade it? Any advice would be appreciated.
Read more
