Archive
Hello i'm facing problem regarding paltalk which i have just installed on my system. I'm using windows 7 and paltalk version that i have installed is 10.0
saying "Login problem Unable to connect (tc-2120)".
Kindly help me out to solve this issue.
Read moreI have folder name outlookABC in F directory when I opened it I found another one name outlookABC and so and I cannot reach my data on it (three notepads files).
So anyone tell me is it a virus and how to reach my files and stop this folder from copying itself.
Read moreI work in notepad many hours per day but there is a problem that I cannot write Arabic language. when I write Arabic there is no problem but when I save notepad then close and open it again I found words in Arabic be like this ?????. When I write Arabic in any other program like MS word … save and return to file again I found no change so please anyone tell me how to write Arabic in notepad.
Read more
My windows is windows XP and I use Windows Server 2003. I tried to run MiniFuzz in my computer but I get error message that unhandled exception happened. So please anyone tell me what this message means and how to stop or fix it.
Error message:
Unhandled exception has occurred in your application. If you click continue, the application will ignore this error attempt to continue. If you click quit this application will close immediately.
When I try to view my devices and software when I start Measurement and Automation Explorer (MAX) I get this error message Data Dictionary Error Detected. So please anyone tell me what this message means and how to stop or fix it.
Error message:
An error was detected in a data dictionary on your local system
An installed data dictionary is incompatible with a previous installed version.
This error may have been caused by a recently installed component.
See the following files for more information:
C:Documents and SettingsAll UsersApplication DataNational InstrumentsMAXData DictionariesmxsSchemaError.log
C:Documents and SettingsAll UsersApplication DataNational InstrumentsMAXData DictionariesmxsSchema.log
For more...
Read moreI install much software in my computer but in the previous days I get error message in Symantec Endpoint Protection installer information.
Please anyone tell me what this error means and how to fix it or how to install any software without getting this error message.
Error 1327.Invalid Driver: K:
Read moreHello guys,
I am into Information Technology and I want to ask if anyone here knows about or is proficient using Google+. I want to learn more about it.
Can anyone here share their ideas and any suggestion to improve my Google+ account. Hoping for some helpful answers and suggestions.
Thanks,
Jennielyn
Read moreI work on Microsoft office many hours per day and I depend on it in a lot of work but in the past days I receive this error message many times that there is error in Microsoft office Visio Viewer 2007.please anyone tell me how to stop this message.
Error message:
A network error occurred while attempting to read from the file C:ProgramFilesMSECachevviewervisioviwer.msi
Read moreFor 2 days now, I started getting this error message in a dialog box about adobe flash player.
It appears even if I don't have any open application.
I removed my Adobe Flash Player and rebooted, then installed it back.
The problem continues however.
A script in this movie is causing Adobe Flash Player to run slowly.
If it continues to run, your computer may become unresponsive.
Do you want to abort the script? Yes / No.
Checking either option only gets rid of the pop-up for a few minutes.
Any solution?
Thank you.
Read moreI have a batch of computer sets to be set-up They all have the same specs and brand.
I was in the middle of trying to slipstream the drivers to my Windows XP SP2 when I got the following error message:
Error!
D-Could not find file 'ati2cqag.dl_'.
Please report this error if it's unexpected.
Write your message in English and attach your 'Last Session.ini' if possible.
How can I fix this?
Read more
