Archive
My Question is that what is the major difference between Windows Server 2003 and Windows Server 2008.
And also I want to know about Difference between Server 2008 and Server 2008 R2.
I wanted to start customizing my report so I hit the Configure option to start the “Report Customizer”.
I didn’t expect that I would encounter a problem. A window popped up saying
B2Win Wizard
Can not open the Wizard. Please click on Help > Update Components.
How do I fix this error?
I bought a new Mikomi web cam today and when I got home, I eagerly went online to download the driver. Unfortunately, I got this message saying “The device cannot be found” and I was unable to proceed. Does this mean my PC doesn’t detect the web cam?
Please give me an advice on this. I would appreciate any help. Thanks!
Read moreI have a problem installing the Belkin UPS Software.
During the installation, I encountered an error notification which says
Error: Repeatedly Running. There is an instance of setup running, please wait.
What should I do about this?
Help please.
Error
Repeatedly Running
There is an instance of setup running. please exist..
Read moreHello, I am using MS Windows XP SP2 and whenever I try to launch Google Chrome in my PC,
I get following error message:
“Proxy Detection Failed: PAC script error. HTTP Download failed.
Connection failure”
Any suggestions please!
Thank you in advance.
Read moreI just need an expert opinion about security warnings related to digital signature. For instance, I tried to install an application but a message popped up asking if I would want to run it even if the application’s digital signature has expired.
Please refer to the screen shot I uploaded. Should I hit Run or Cancel?
Warning - Security
The application's digital signature has an error. Do you
want to run the application?
Publisher: Blackboard
Read moreI received an error after I tried to set up a thermocouple task on PXIe-4353.
This device uses a CJC channel on another mechanism and is connected to other devices as well.
If you have any idea how to deal with this issue, please help me out.
Thanks!
DAQ Assistant Error
Error -201426 occurred at DAQ Assistant
Possible reason (s):
One or more devices do not support multidevice tasks.
Device PXI1S1ot6
Read moreI once had this program on my computer but I needed to uninstall it after I encountered a problem launching the program.
When I try to re-install, I encounter yet another problem. The error message says something about “InstallShield error code-6001” and also states instructions to close programs, empty temp folder and check internet connection. I did just what were written and tried to re-install but I was still unable to do so. The same error notification came up.
I really need a hand on this. Thanks in advance!
Read moreI receive the following notification when I try to use or install some programs or open some files.
“FileSYNSOACC.DLL could not be located in the windows system folders”.
Where should I be able to find FileSYNSOACC.DLL in my computer? Or just tell me how I can fix this problem. Thanks.
Read moreI have a Windows 7 computer and I am running a Virtual Box v 4.1.6. I also have IDE Controller - Empty, and a SATA controller - connected to the VDI file.
My problem is I get an error notification, “unable to mount root fx”, whenever I try to use Fedora. I read some thread about this error and I think I have to change my storage settings to fix this but I’m really not sure how to do it.
I hope someone here can tell me what to change and how to change them. Thanks for your time.
Read more
