Archive
In Windows operating system, in every version I have operated. Till now I haven't seen the System32 file. What is this? Why this is named like this, why the "32" is given in the file name? What is it's job? I have seen that if I delete this file, the system fails. Why? Why is this file is so important and if the file affected by any Virus what happens? Is there any way to repair this file? And is there any way to replace this file if it's deleted?
What should I do if the system32 file...
My Elite MoBO has a complex multichannel audio output capability which is beyond my comprehension (or interest). I bought a PCI sound card to replace it and this works fine for my purposes--streaming radio, system sounds and the like.
However, it is a rickety thing--very often minor activity causes loss of access and a check in Sounds and Audio will show no audio device detected. I then uninstall the driver for the PCI card, shut down and reboot and the sound is back until the next problem (which has been as simple as changing the volume control on...
I have successfully installed the NI USB 6008 device on quite a few XP Embedded machines. I'm not sure if XP embedded is supported or not. But it seems to have worked up until now. We now have a new batch of XP embedded machines and I can no longer get the driver to install.
I have tried using both the NI DAQmx v9.0.2 and NI DAQmx v9.2.1. I have also tried the full download (all crazy 1.2 GB of it) and the 'Core' version. All of the versions claim to install successfully but when I plug the USB-6008 into the USB port Windows...
Read moreI planned to realize my small business involving 11 computer units, including the server. The type of my business is internet gaming and savvy. I want to connect all units to the internet, but I don't have an idea in configuring it. I am looking forward to my business and I really need to know what is the ideal configuration.
All other hardware devices and software applications used in my network are already there. As of now, we are using DHCP to connect to the internet automatically. I can't differentiate from Static because I don't have an idea how to...
Read moreHay,
I am using Microsoft Windows XP SP2 home edition and I am having a problem with my PC’s performance. The issue of which I am been victim is that whenever I use to open more than three windows of my internet browser, my computer goes hanged and everything stops responding.
Even after this I cannot shut down or restart my PC because the computer is suppose to be totally jammed than. I have tried lot of things to overcome at this issue but I am not been able to fix this issue via any of my adopted method.
For the solution...
Read moreIs overclocking a laptop safe? If so does it really increase the speed of your computer? Does anyone here know a tutorial or step by step guide to follow.
Read more
What are the difference between worm and Trojan horse in computer virus.
A computer virus is a malicious code which deletes or multiplies system files. A worm is a form of virus which affects computers in a network. Do Trojan horse function the same way as worm?
Then what are difference between above two forms of viruses? Do viruses affect routers and switches? Someone to tell me? What are the solutions to a system affected by virus.
Read moreI have a 8G kingmax microsdhc which I used for a week on my cell phone. I stored files and images in my mp3, then there came a time when I took off the microsd from the cell phone and placed it on the adapter and stuck it on my laptop.
I tried to open it but it won't follow the command. It says something about, not being formatted. So it asked me to format it. Even though I knew that I may lost all files, I followed the instruction to format it. I was surprised when something popped up and...
Read moreWe are presently writing an application in Java. This application scans a predefined set of folders and gets a list of files in each of them. Then the application reads the file as a byte array. Next it calls a Web Service to submit the binary image. Lastly it moves the files to a different location. These set of actions work perfectly. The problem we have is that the java application is picking the file when in reality, the file is not complete as yet. How do we prevent this?
Read moreI am using Opera browser for quite a long time now and I believe that this is the best browser when using Subsonic Music Streamer. But recently, I am encountering a problem with the opera Cache. Something has been varied but I am not sure if it’s with the new Opera version or the updated version of Subsonic. When I play a song on an album, the song will be added to the playlist by default and the VLC player will automatically starts. My problem is, when I edit the playlist or remove any song on the playlist, the...
Read more
