Archive
My HP Photosmart C7250 won't print because it doesn't detect the other cartridge. It always says that the cartridge is empty. I've followed the instructions on how to clean the heads according to the HP manual. I already replaced the cartridge multiple times.
This printer has been working fine for 6 months and I'm sure I am doing it right. Now I bought a new ink and it says status light that says that the ink cartridge is empty. I don't know if I need to buy a new printer or what.
Any help would be greatly appreciated.
Thank you. ...
Read more
I was running the Mozilla Firefox when I received this error message “Error Loading C:WINDOWSsystem32wscuiex.cpl, 1% is not a valid win32 application.”
I have been utilizing Mozilla Firefox since before and everything was working normally. It just starting yesterday that this error has been continuously happening until today.  I am just wondering if you have a win-win solution on my problem because I cannot rely on myself. My knowledge on computer is very limited.
I tried referring this to my Auntie who is a computer instructress but she was not able to resolve the issue. According to her, the error message...
Read more
Care to help me please! I had downloaded a McAfee anti-virus and when I installed it, the following error appeared when it was about the finish the installation.
File Error Cannot find the shell.dll
File Error
Cannot find the shell.dll.
The error that was displayed in the screen forcefully stopped the installation of McAfee.
I had referred this problem of mine to my friend and he used the System File Checking Tool to check the damaged and/or replaced files on my laptop. After his application of the system file checker that he used, he restarted the laptop...
Read more
Last night, I was so busy doing some research for my research study when my PC rebooted and restarted by its own. It was almost done in the booting process when it hanged-up and the following error:
Windows could not start because the following file is missing or corrupt: /windows/system32/config/system
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select 'r' at the first screen to start repair.
I did various researches from various computer support sites on how to solve the concern on my PC and majority of them suggested...
Read more
Hi guys,
I need some help from you who have wide knowledge in computer troubleshooting.  Last week, I ran the disk de-fragmenter utility of my PC to reorganize the noncontiguous files that I have in my hard drives. While it was running, I received the check disk error and it instructed me to run chkdsk/f.
When I initiated the disk check in the command prompt, it informed me that the hard drive which my laptop is using was used by another volume. I repeated the steps carefully but the de-fragmenter kept on showing me the same error.
Please give me any recommendation...
Read more
I had just installed the Redundant Array of Independent Disks (RAID) into my laptop to increase the performance of my hard disks as suggested by my uncle. The RAID’s installation was actually successful but 2 minutes after the successful installation, my laptop worn-out in the RAID configuration with a black message saying
Windows cannot start because the following file is missing or corrupt: <Windows root>system32Hal.dll. Please re-install a copy of the above file.
And so, like the screen had directed, I restarted my laptop and reinstalled the RAID again. But it seems that the suggestion of...
Read more
I have a Windows Vista Home Basic installed in my laptop. Every time I started my laptop and while it is in the middle of the booting process, I received this error message
Windows has blocked some startup programs
Windows blocks programs that require permission to run when Windows starts. Click to view blocked programs.
This frustrating situation really made me annoyed every time I opened my laptop. I don't want this error message to appear when I start my laptop. I already asked a help from a friend who has knowledge in computer applications but he wasn't...
Read more
Thanks for your technical assistance. I got this error message “Error loading C:WINDOWSSystem32NvCpl.dll” every time I started my PC. This kind of error usually happened at the end of the booting process. My uncle who has a background on computer troubleshooting, cleaned and repaired the operating system through the Tune Up Registry Cleaner but the similar message error had been displaying.
A day before this problem occurred, I had upgraded the RAM or the internal memory my PC from 128 MB to 256 MB. Was the upgrade of the RAM the main cause of the problem? How can I fix...
Read more
I had formatted my PC because of the robust viruses that affected its performance. When I started my PC after the format process and while it was in the booting point, I had encountered this error message “Keyboard error or no keyboard present. ”
It offered me options to choose between pressing F1 to continue and DEL to enter into the setup interface.
Keyboard error or keyboard not present
Detecting Primary Master
Detecting Primary Slave ...
Detecting Secondary Master...
Detecting Secondary Slave ...
Read more
 My best friend’s computer is experiencing the following error message every time he started his personal computer “PC fan has failed” while the black screen on the other hand can be observed. Then it directed him to hit the F2 for him to proceed to the next interface. Before, it took for about 5 minutes for his computer to shut down but recently he had observed that it already took for about 10 to 15 minutes to shut down.
One of our friends suggested to him to open the case of the system unit to double check if the fan...
Read more
