Archive
I have an old laptop bought about 3 years ago. For a long period of usage it was almost damage, the only thing that is working and can be reuse is the hard disk, the 256mb of ram and the sound card. The rest are totally out of order and unusable.
Now, I want to make a portable hard disk using my old one. And I’m planning to buy an enclosure case; the only problem is I don’t know what kind of connector needed for my hard disk. As far as I know there are two types of connector available...
Read more
I got this error when I boot up my computer. File ntoskrnl.exe could not be loaded.
The error code is 21
Setup cannot continue. Press any key to exit.
File ntoskral.exe could not be loaded.
My computer is Windows 2008 operating system.
I am about to change the Windows 2008 to Windows Vista Premium. That error message came out when the OS (Windows Vista) tried to load the system. The OS couldn't continue to load up because of that error "NTOSKRNL.EXE". I did check the CMOS BIOS set up...
Read more
I do not understand why this happened after I updated my version of ‘Windows Vista Home Premium’. Windows Defender ‘ was preloaded on the operating system and I could not uninstall it.
Windows Vista Home Premium. Windows Defender
Application failed to initialize: 0x800106ba. A problem caused this program’s service to stop. To start the service, restart your computer or search Help and Support for how to start a service manually.
After reinstalling my OS, the system was automatically updated to a service pack and the problem listed above happened after I updated it. Whenever...
Read more
I’ve been wondering if it is safe to delete config.msi folder in my root drive of my windows. I’ve open the folder and found out that there are some files with the extensions of .RBS and RBF. What are those files by the way?  I tried to delete the file but before that I save a backup of them in my USB flash drive just in case an error will occur on my computer system. So far I haven’t encountered any errors,  my computer seems to work normal as before. But for precautionary measure I haven’t deleted the backup...
Read more
It is so annoying that when you visit some site and there are some pop-up add that will definitely appear even you didn’t click it. Most of them are added on every link without knowing that they exist on that link. I think that the best way for them to get noticed but for some people like me it is a nuisance on the net.
I try to find solutions on how to eliminate those annoying pop-up and found out that there are lots of pop up killer available on the net. I Google some software on the net and...
Read more
How can I fix a computer when its lag?
Last night, I played online game while I'm playing I noticed that the was slow moving every time I moved the mouse and sometimes paused for a minute and then after a minute it will moved again. I cannot played well so what I did was I reboot my computer and wait for it to finished rebooting.
When its already I immediately open my game to played again. I thought it was okay already but while playing with it for about 30 minutes it suddenly paused again. I decided to turned it...
Read more
I have been cleaning up my computer, delete the unnecessary folder manually.
As I go through the C drive I’ve encounter unfamiliar folder NTLDR without any hesitations, I delete the folder.
At first the computer doesn’t show any error so I think that everything is fine, and I’ve done the right thing.
By the way,I’m using windows XP home edition. After a few hours of using the computer I shut it down.
I woke up this morning and open my computer to do my daily work, but I was shocked because my computer doesn’t even boot. It only shows a black screen and...
Read more
Hello
I'm working on a new desktop with Windows 7 Home with 4 GB Ram and 320 GB HDD installed. I'm using a desktop application that apparently only working properly in Windows XP so I was told to try and use Virtual PC. The problem is Virtual PC cannot work properly in Windows 7 Home.
I have tried to reinstall Virtual PC but still failed. I know for a fact my colleague use Windows 7 with Virtual PC so he can run the desktop application. What did I do wrong with the installation of Virtual PC. Is there any additional steps...
Read more
Please, if anyone knows about my problem, feel free to post your answers! My computer automatically shuts down without any further notice. When I start the computer and reach the desktop, it takes only 5 minutes (as estimated the time) and shuts down, without any error message or even a warning prompt message!
Shutting down.
I just don't know what else to do.  I don't have any idea with regards to this problem. Please help me my computer is in danger. I think  I can't fix the problem as I don't know such troubleshooting issues! All I...
Read more
I'm encountering this Code39 error with DVD/CD-ROM since I’ve tried to fix some issue with my DVD drive. I’ve tried many things to fix theproblem but none of them seems to work. Some of the few things I’ve tried are; uninstalling and installing the DVD drive from the device manager, installing ccleaner program run the registry fix option. There are lots of registry errors detected after that I try to fixed them but it doesn’t help me with my problem. I don’t think that my DVD-ROM was damage. How can I figure out what’s the problem with my computer? I...
Read more
