Archive
Hello Experts,
I switched my Maverick to Natty to learn some of it features and gain additional knowledge with it.
I tried to apply some of my configuration on a new system with 3 monitors. In Monitor 2 an error appears after creating a new panel and adding applets to it. Applied to Monitor 3 same error faced.
What could be the cause these were it is functional in Maverick?
Any ideas are greatly appreciated. Thanks!
Error appears in my screen 2 and 3.
Error:
Notification Area has quit unexpectedly
If you reload a panel object, it will automatically be...
Read moreHello Everyone,
After I do some improvement on KDE 4.6 to Alien Bob's KDE 4.7 packages in Keisty fawn and re-configure KMail version 1.9.6 setting then tried launched KMail but it fails to start receiving an error message. Is there other information to configure my KMail to start properly? Please give some ideas to prevent this kind of error. Thanks in advance!
Error KMail:
Error:
KMail encountered a fatal error and will terminate now. The error was: Failed to fetch the resource collection.
Read moreHello Experts,
I’m new with Kmail and just follow some of its default settings. I had no problem when it comes in uploading and downloading file but suddenly when it comes to deleting mail from the server gives an error. Please give me an idea on how I can handle this error. Thanks in advance.
Problem encounter:
Hi All,
As I was opening accounting program in my computer and importing some files from our server the unexpected error appear that causing me to pause my activity. Yesterday, it was surely operational after updating accounting program but now can’t proceed to import some of my files. I try to restart my computer then log-in to our domain and repeat process of importing but same error appear. Any good suggestion is really appreciated. Thanks!
Error message:
Could not read file. The server terminated the connection.
Read more
Hello Experts,
After doing some upgrade of my old openoffice.org to openoffice.org2 in my Ubuntu 7.04 and restart the gnome-panel I get error message. I’ve reinstalled openoffice.org2-common & openoffice.org2-gnome, but the problem continues.
Any help would be much appreciated. More power to Techyv Experts!
Error:
Failed to load image openofficeorg-writer
Details:Icon not found
Read moreHello Everybody,
I have a problem in Zotero when capturing of citation information from my whole webpage.
I recently provide latest version of Firefox for Zotero that will run smoothly and update my ZoneAlarm after doing an improvement in my Windows Vista system an error occur in communicating Zotero.
In my other PC, Zotero is doing well in my XP.
Could someone help me regarding the trouble encounter?
Thanks in advance.
Zotero - Error
An error occurred communicating with Zotero. Please ensure Firefox is open and try again.
Read moreHi Everyone,
Here I go again have some problem with KeePass when already done the developing data in archiving management system made and have to import the other file on my program created. I was wondering why I can’t proceed to import my file were other files can be import. What wrong with my KeePass accessing with my program created?
Can guide me with this problem. Thanks in advance for helping!
Message box received:
Error:
KeePass
Importing/exporting data from/to KDB files is only supported on Windows (because a library is
Please use a different file format for migrating your data.
A KeePass was installed in my other system unit Windows Vista 64bit with an update version of net framework 3.5.1. Opening the application was unable to start correctly.
I rather temporarily disable my NOD32 that some of my application would not start when it is on normal mode. When try to launched KeePass same error surprise me.
I reboot the system and have scan the registry of KeePass then run again but still error appear.
I'm clueless what's causing this, but it's quite annoying...
Thanks
Application Error:
KeePass.exe – Application Error
The application was unable to start correctly (0x000007b). Click OK to...
Read moreHello,
I successfully installed NeroVision Express, and it worked then one time I got this error message, see below.
Untitled Project *[DVD] – NeroVision Express: NeroVision.exe – Application Error
The instruction at “0x003406f6” reference memory at “0x00f70588”. The memory could not be “read”.
Click on OK to terminate the program
I searched the web and learned that this might have been caused by a virus or malware. I was not sure on how to resolve this. Any advice to fix the problem will be much appreciated.
Read moreHi,
I was trying to launch Phoenix software in my Win XP when I got this error message (see below).
phoenix
Windows cannot find ‘phoenix’. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
I was very sure that it was working yesterday. Anyway, tried to look for a solution in the internet but couldn’t find an applicable one. Hope this forum could help resolve the problem.
Please help ASAP.
Read more
