Archive
You can restore your operating system, simply by using your windows system tools, just select the restore system, then select the date where your Desktop is working, then follow instructions until finished.
Read moreI downloaded videos for my phone from youtube and when I transferred the file it say "INVALID FORMAT"
I also tried to open up another video still the same over and over again. I need to show my videos to my friends from youtube through my cellphone.
Help
Read moreProblems with my Skype please help. Cant see messages from room and cant even send messages. I'm getting frustrated now its been two days now and cant use my Skype and I need to work for my job.
Read moreMy desktop is newly installed XP Operating system but my audio didn't work.
Can anyone suggest possibilities. where i can start checking and sorting the issue
Read more
Check your LAN card, if you are using a DHCP or OBTAINED. If settings are obtained, it needs to key in the IP address, Gate way and the DNS what your ISP provider gave.
Read moreHi,
I was using Windows XP and it was good at the first time, However, Now I cannot use my Windows XP and it has many problems. Actually, I want to restore my Windows XP and want to use it like earlier date. If anybody help me to restore my system I would be grateful.
Thanking you,
Best Regards,
Tamanna
Read more
Hello everyone,
I'm a new Mac user. Recently, I've purchased MacBook 2. 4GHz ,Intel Core 2 Duo, 2 GB DDR3 memory, 250 GB hard drive.
I want to install Office 2008 lIcensed Mac version, in my new MacBook. I already got Office 2008, Non licensed software in my Mac. I've removed the Non Licensed, Office 2008 from my Mac, (moved it to trash) and then tried to install the licensed version but it doesn't work.
Anyone help me to install my Office 2008 Licensed version in my new MacBook. I need the licensed version of Microsoft...
My computer is directly to my modem as write this question. As you can see, I can go online. The problem is I can't go online if I connect my router to the modem, even if I wire my computer directly to the router.
My modem came from Comcast. My router is a WRT54G v6.
Read moreI have cable Internet at home. I decided to change the modem that the ISP gave me.
I thought it was a good idea.
The problem is, I can't go online thru the new modem.
If I replace the new modem with the old modem, the Internet works.
My new modem is a CM100.
Read more
