Archive
I have a problem with a Microsoft Access database. I'm developing a desktop application using Access for the database. I know that Microsoft Access can develop applications as well, but in this case I only use the database side while the application was developed using Visual Basic 6 and for reporting side I'm using Crystal Reports.
I know it's probably a little bit old fashioned that I'm still using Visual Basic 6 while .Net and Java is available to use, but it's what I'm familiar with. I'm using Windows 7, 32 bits with 2GB RAM.
Anyway the application is running well...
Read moreI am using laptop computer at home and i work as a contractor on a online job site. This job requires clear internet connection to be able to do the job accurately. In the middle of my work, the network disconnects and the connection is gone. I restart the computer just i thought when doing that the connection will back to normal. But still the connection were out.
How can i reconnect the network? I don't know all about networking for my job is a writer. Can you help me fix this out? I maybe fired from my job if...
Read moreHello everyone,
I really need help on my PC. I have an Intel Celeron at home running with a MS XP OS but the performance of the PC is very slow. It takes about 2-3 minutes before an application opens after clicking and it usually "hangs" for most of the time. I have tried removing useless applications and software, reducing CPU usage and display settings but still my PC is very slow.
I cannot spend too much on upgrading the PC because I had spent a lot of money trying to fix my monitor, so.
Can anyone help?
What to do?
Thank you.
Read moreExcel, Ms word document and folders. Those are the files i saved in my laptop computer. This morning, i open one of my files and as i have noticed the file was not there. I check the folders but the folders are empty? I search the files but the result turns zero?! I click the folder options and enable the show hidden files but it's not working! I restart the computer still the files are not there?
What is the problem of this? Is my computer had a problem? Is my laptop had a virus? I have Antivirus software then...
Read moreI have numbers of photos in my desktop computer.
I want to upload them in a social network site.
When I begin uploading the photos, the error prompted on the screen and say's "Invalid image format JPEG".
As I check the photos, the file format is file.exe?
How did this happen?
All I know is JPEG format but why has it turned to be file.exe?
Is this a virus or something?
How on earth change the file format?
How can this be fixed and turn into the JPEG file format?
I'm excited to upload those pictures so please, a little help here!
Read moreI am currently encountering a printer problem right now.
I'm about to print copy of my files then suddenly my printer seems not working properly.
The model of my printer is Canon MP145.
As I've seen, there are two cartridge inside my printer, the colored and the black.
The colored just run out of ink, so before I print the copy of my files I set-up the printer to print it as black and white then the printer wasn't responding.
Nothing happens at all, does anyone here encountered this problem before?.
Help me please regarding this issue!!
Read moreHello! My task is to design a network in a workplace. The company using CISCO Router for my routers, 25 work stations and 3 CISCO Switch. I'm a little bit confuse about routing protocols. I can't decide which protocols I will be using by configuring networks. Maybe you guys give me advice whether i will be using EIGRP or OSPF protocols. Which of the two is the best protocol to secure my network? So that when someone tries to access my network illegally, they could not be able to connect or even access the server.
Help me to decide which...
Read more
I bought a scanner yesterday and I want to connect with my computer. I thought setting up scanner is the same way of setting up a printer. But apparently i don't know how to set up and connect to the computer.
Can you guys give me some brief instructions so that I can successfully connect to the scanner to my computer? Have something' to do importantly so that's why I'm eager to know the set up. And by the way, is it advisable to connect the scanner using laptop? Would it be working? If that's so, what are the steps...
Friends! Need help here!
It's been awhile since my laptop experience this problem. When i check this site i found out that this is the way that problems are pretty solve. Ok to begin with, i am searching for a dating site in the web and as i keep on browsing my computer hang up! I leave the computer for a minutes but there's no action has been done, still it hang up.
I press the Ctrl+Alt+Delete option to take me to the system utility task manager to restart the computer. I leave again the computer to be able to access...
Read moreAfter I reformatted my Presario Cq41 laptop there's a dialog box that keeps popping up.
I don't have any idea of what it is all about. I keep searching on the net and find no answer.
I really need help, it annoys me, every time I open my laptop it always appears.
I will list down all the things I've done to solve my problem
- I try to run my Ccleaner program. Check all the bad registry files and delete it though nothing happens.
- I found a post from a site telling me to disable Quick Time player on the start-up cause it... Read more
