Archive
I have to use VPN for different times to do my Internet marketing job.
So I use HMA!Pro VPN 2.6.6 for 11.52 USD per month. Previously I used a modem which connection was very slow. But i could connect to VPN on this modem. Now I have bought a new Wimax modem for getting high speed connection.
I feel happy to browse in the Internet by this High speed connection now.
Problem is there I can not connect  VPN  to this modem. When I open VPN and click to the connect button it remain stopped.
But It is urgent to change...
Read more
How to remove "BOSD" or Blue Screen of Death to my computer?
Whenever I start up my computer the Blue screen of Death appears and I have to restart my computer. I managed to get past the screen again and again, and when my computer continue to open up to desktop it becomes blue screen again. Only to have a bunch of error messages telling me the files in many of my applications (Google Chrome and Yahoo Messenger) are corrupted. I get many different error messages because of the blue screen.
Please help me solve this problem. How will I remove...
Read more
Can someone help me?
I have a HP G60 laptop running on Windows 7 Home Basic. The problem is that I can’t access the internet, using the dial-up connection. I keep on getting error messages. For instance, “There is no dial tone."
When I click on the internet icon, I get a message that, “Connection does not exist, you cannot connect to the internet because you are working offline”. I went to the modem options and unchecked the, "wait for dial tone before dialing" check box and redial the second time. This time round, it started its...
Read more
It is less than two week ago my cooling fan suddenly made bad sound and stopped. I cleaned it and set again. After it was working well. But yesterday I was hearing music and browsing internet. It has stopped again with a shitty sound.
Now its okay. But i am confused there is a big problem. What should I have to do? My motherboard is Gigabyte 7NF-RZ the CPU is running at 1.05 GHz.
Is it alright? I went to crank the setting and the system just crashed. Now i don't understand it the problem for what. Cooling fan or Motherboard?...
Read more
How to fix the multiple problems of computer?
About five days back I got the "Recycler" virus in my computer and did not know how to get rid of it. I tried to download several Antivirus software to remove but no luck.
I thought we can give it some time and it will fix automatically, but when I tried again, my system displayed a message "Boot problem insert disk and restart" or something similar. I don't know what it means so I just kept restarting the system and it finally just turned on. What is the possible solution for my computer?
Read more
Hey guys, I want to install Adobe Photoshop CS3 on my desktop computer but I don't have an original installer that's why I went to my friend who is working at computer shop, my house is just 20mins away from the computer shop. I requested him to burn a 2 copies of his Adobe Photoshop CS3 into a cd. After he copied it at the cd, he tried to run the software and it is working normally. Then when I went home I'm excited to install the Adobe Photoshop CS3, but unluckily  the cd cannot be detected at my dvd rom. Before I left at...
Read more
I am from Mauritius and I got some major issues with my Toshiba laptop. The laptop just kept on heating up till it switches down due to overheating. This problem has annoyed me lots and I took the correct screwdriver to open the laptop casing to see what wrong inside is. Obviously the cooling system has to have stopped working. But I still hear the sound of fans running before opening the casing.
Then I discovered that the cooling system inside is made up of 3 fans. They are interlinked in such a way to evacuate the heat through the...
Read more
How do you remove "recycler", from the computer?
I was encoding my school project in MS Word and then after I finished it, I got my USB and saved my project. Before I removed my USB I noticed that there's a folder named "recycler".
I'm curious and that's why I opened that folder, but nothing happened and then I inserted my USB again for some editing on my project. I was shocked because my files were gone and even the project that I encoded was deleted already. And then my friend told me that my computer had been infected by some...
Read more
I have a HP Pavilion laptop, not more than 2 years old. I was plying loud music using VLC media player, full volume from the internal speakers, no connection to external speaker. I left the room for a while and when i came back i noticed the speakers we not producing any sound. I don’t share a room with anyone and i locked the door while moving out, nobody had interfered with the computer. I thought the computer had hanged up so i restarted it and added the same music folder to the play list. It played the music...
Read more
Which is the best of all browsers?
Any updates with this question
Regards
Read more
