Archive
Hello fellows,
I met an issue yesterday when I installed new MSN messenger on my machine.
Windows 7, 64 bit operating systems. The error message was " Error 80048820"
Windows Live Messenger
We can't sign you in to Windows Live Messenger
Signing in to Windows Live Messenger failed because the service is temporarily unavailable. Please try again.
Error code: 80048820
Read more
I've use to "Registry Mechanic" antivirus and it work well. But the problem is few weeks ago i have installed Symantec antivirus which was out of date. And it does not work fine. So I think i do not use it . But the antivirus could remove from my add/remove center. It is possible to remove from my pc ? Walter
Read more
Hey guys,
I'm currently experiencing a JavaScript "Object Expected"  error over the main menu on the top of the site
Any help would be appreciated.
Read more
Hi Anyone has the Roland SC-545EX printer Configuration files. I bought the machine without software and not able to print. My others Roland using the Wassath software require the configuration. Thank you
Read more
Thank you for viewing the question and thanks in advance for the help. I need assistance in setting up IP Routing (Dynamic Routing and Static Routing) in Windows 2008 Server? Also, can you please direct me how to use the RIP router to add networks?
Read more
Hi experts,
I have an HP Mini and My Computer have a Virus Problem so please help me. I'm not sure if my warranty is still good..
thank you
Read more
HI there,
Random reboots and it appears to be the fault of dxgkrnl.s
Windows 7 64 bit and have a Geforce GTS 450 graphics card.
I would be extremely thankful.
Read more
I am setting up a local area network at our office. I like to know what kind of peripheral do I have to use where I can be sure that I will not suffer from collision problems. I have both switch and a hub, which one is better to use?
Read more
Hello friends,
i have a problem regarding to play SILENT HUNTER 4,  i get the BSOD error 0x00000050,
system mechanic to clean my pc but it says "no error now", so here is the dump file and the msinfo32.txt its in .txt format.
I think that should have all the informtion you guys need, looking for reply as soon as possible. Thanks alot
Read more
I have a DI-LB604 Load Balancing Router, and I use to load balance my two internet connections, the sky and globe broadband. After setting up plugging in two connections at two WAN ports, then distributing connection to another switch then to our workstations, we are experiencing down internet connections. Is there any other setting I used to configure in order for this device to perform properly?
Read more
