Windows XP shows Command Prompt Error
Hello sir,
When I started command prompt in Windows-XP, it arises a error message frequently.
What is this?
How can you reduce this? You can see it below.
Is it necessary to I reinstall the operating system.
If not, then how can solve?
End Program – C:WINDOWSsystem32command.c…
Windows cannot end this program. It may need more time to complete an operation.
To return to Windows and check the status of the program, click Cancel.
If you choose to end the program immediately, you will lose any unsaved data. To end the program now, click End Now.
