No of visitors who read this post: 173
Category: Windows OS
Type: Question
Author: Richness
No votes yet
In the launching of Microsoft Windows 8, people are asking what will we get from this update? Is this compatible to our current softwares installed to our respective computers once we update it? The computer drivers and others will it work properly with this new version of Microsoft.
Comment viewing options
Windows 8 provides influential novel habits to utilize shared technology especially in connecting people and it is created for the best performance on a range of appearance factors—particularly the new versions of touch gadgets and devices.
The new release of Windows 8 should run the identical devices that run Windows 7 as well. Maybe it will be necessary to update software or to uninstall and re-install a program after you have set up Windows 8.Of course when you start installing Windows 8, it will run a compatible test first.
It is powerfully advocated to be skilled computer user. You should be aware of the advantages and disadvantages before installing the software, since it is still in progress. There is a possibility to bump into faults and errors, so you have to be able to face them.
Especially you may encounter errors such as:
-programs that can’t be installed or they don’t run normally.(included the antivirus software as well.)
-hardware also may encounter problems (video cards, sound cards, printers)
-there is a possibility to have connection problems.
-you may have corrupted files.
My opinion is that you should
You should cautiously poise the hazards and booties and think thoroughly if you can face all these problems before you install Windows 8
