Hi. Live type is awesome software for displaying animated titles of projects and it is satisfying me but there is a small problem with it. Some time font as well as pictures merges into another and shows very bad result. I tried to fix it by changing font style but failed. Please tell me how to set this problem.
Why some fonts seem to shake in live type software on Mac?
Hello Steve Randle,
If you have this problem then you have to reinstall your software. As there are many viruses that can effect the program. So now in reinstalling try to use the RUN AS ADMINISTRATOR command so that your software can install properly and can never give you problem like that you are now getting. But there is a option of trouble shoot in the help menu you can get it clear from that place. Trouble shooting the fonts will help you to recover your software default settings and you can easily make them clear in the next use.
