Where can I acquire a fully functional to schedule tweets OSX?
Hallo! I would like to schedule tweets OSX but I am wondering which applications are out there for that. There are several options like Timely, OS X Twitter Client etc. I do not know which one is the best and most secure to use on a professional setting. For the developers out there, is it possible to code your own application and enjoin it with Twitter to perform similar functions? If, yes, is there a sample code to check out? Cheers!
Answered By 35 points N/A #138149
Hello Jane,
The two best applications for this is Tweetdeck and Tweetings. The first one I mentioned is free and the latter costs $2.99 for your MAC OSX. There are also mobile versions of Tweetings, for Android, iPhone, and iPad. Yes a good developer can easily code an application that performs similar actions to the ones I have mentioned but it may end up costing you more.
Thank you,
Luz M Terry
