hannahwtc
10 points
Posted on - 05/03/2013
Hi there!
This has been boggling my mind for a while now. I have PDB files that I would like to convert to txt file format. I am running Mac Operating system on my personal computer. What PDB converter Mac from PDB to txt can I use to have this done effectively without loosing data or corrupting the files? Thanks.
What PDB converter Mac from PDB to TXT is the most effective?
Hi Hannahwtc
ABC amber Palm is there for you. You can download PDB , PDF , HTML and DOC to what ever you choose from the following :
PDF, HTML, CHM, RTF, HLP, TXT, DOC, WPD, LIT, RB and Clipboard. It is totally free and only 1.3 Megabyte size. It has great number of options there for you to use like encryption , compression and fonts.
You can download it from here.
