Slipstream error message for my PCs
I have a batch of computer sets to be set-up They all have the same specs and brand.
I was in the middle of trying to slipstream the drivers to my Windows XP SP2 when I got the following error message:
Error!
D-Could not find file 'ati2cqag.dl_'.
Please report this error if it's unexpected.
Write your message in English and attach your 'Last Session.ini' if possible.
How can I fix this?
Best Answer by Edmund Joseph
Answered By 75 points N/A #87172
Hi Erwin, provide more background information so that we can be able to assist you. You have not specified the model of the PCs you are installing on, what application you were using to slipstream  etc, and on what point during the slipstreaming process did this error appear.
Answered By 5 points N/A #87175
Hi there user:
What happened here is that you typed a particular name to a folder which is just too long. It was unnoticeable, but the truth is it affected the file inside the folder. Files were locked and can’t delete.
This is a case of ati2cqag.dl file. But once you rename or shortened the names of the folder, the files will become detectable, and you can now add drivers.
Problem solved!
Thanks for posting.
Best regards,
