Receiving error 0x80070005 on my Vista.
I have recently installed a windows home server in addition to a Vista PC.
The Vista PC is connected using the “home server connector software”.
Whenever I try to get access to the shared folders on the server, I got the following error message.
Now I have no idea that what is this error, what are its reasons, causes and ultimately its solutions.
I have been receiving this error since day one and not as a sudden error.
The error remains even if I turn off the firewall in Vista. Also,I am only able to read folder files and not to delete or write.
So, can anyone please help me out as I want to be able to share all the content in these folders throughout the house?
Best Answer by bruce57
Answered By 5 points N/A #79938
The error 0x80070005 mostly occurs when a scheduled task in Task Scheduler becomes corrupted. The error message usually shows “Access Denied”. It is far clear that the error is about security issue,and it finds an error in the access.
It should also be noted that this error is quite serious and can lead to permanent damage to your system if left unsolved.
Following may also be a reason for this error.
1. There will be some problem with the administration events log or the application which has MS.
2. There may also be some technical problem, and that’s why “Check for updates” appears.
3. The error can also occur when the computer name is known and it does not have any IP address mapped.
To resolve this error, following tools can be used which not only will detect the source of your problem but will also repair your system automatically. Download from any one of the following links.
Download Driver Update Software – updates the drivers that control your computer
Download 0x80070005 Repair Tool – helps fix 0x80070005 on your system
Sometimes this error may also be caused by some spy-ware or virus.
So it is recommended that you some tool that removes such infections.
Answered By 10 points N/A #79940
Hallo Fred,
To resolve that issue, you will need to do the following:
  • First, you will need to download AccessChk, a tool that will enable you to evaluate the access level of the specific users or groups which include the files, directories, Registry keys, windows services as well as global objects.
  • After that you will save the zip file on your desktop, and then extract the file:
  • Next you will open the AccessChk folder, and then hold the shift-key and then right click in the window.
  • You will then choose "Open Command Prompt Here".
  • A command prompt window will come up with a similar prompt: C:Users<USERNAME>Desktopaccesschk>
  • After that you will need to type the following command and then press Enter: accesschk.exe -s -n "nt servicetrustedinstaller" -k "hklmsoftwareMicrosoftWindowsCurrentVersionComponent Based Servicing" >accesskchk.txt
  • Next you will close the Command Prompt Window, and then open the Accesschk folder on your desktop.
  • After that you will double click on Accesschk.txt to open Notepad.
Carl
Answered By 590495 points N/A #306790
If the Vista PC is trying to access the shared folder on the server PC, make sure the resource or the shared folder is literally “shared.” If the supposed shared folder is not actually “shared,” it will not appear on the Vista PC. Also, make sure the folder is not password protected.
If the shared folder is password-protected, it will prevent the Vista PC from easily accessing the folder without the password. If you need to protect the folder with a password, you have to map the shared folder to the Vista PC with the correct password otherwise the resource will not be accessible.
Both PCs should also be on the same workgroup so the machines can see each other on the network. If the other machine is set with a different workgroup, they will not be able to communicate with one another on the network.
