A problem opening mobile video clip 3gp.
Hello experts,
A problem opening mobile video clip 3gp. My mobile phone was Samsung galaxy y and my friend sent a video clip with a 3gp format via Bluetooth. After sending the video clip file, I tap the open button and got some error message about compatibility issues. I hope you can give me some way to open the mobile video clip 3gp. Thank you.
Best Answer by Deval Hicks
Answered By 0 points N/A #186485
Hello Benjamin Benjamin,
Sad to say Samsung galaxy Y doesn't supports that kind of file type.
Most are MP4 and AVI.
Try converting it in a Video converter that can be downloaded from your PC.
Hope this helped you!
Answered By 0 points N/A #186486
Hello Benjamin,
Samsung Galaxy Y does support 3GP video clips. So only problem might be the file got corrupted during transfer. So ask your friend to send that clip again via different method (email or in USB). Then transfer it in your mobile phone. It will work.
Thanks
Answered By 0 points N/A #186487
Every mobile set can’t open all types of video files and every set has some specific compatibility with specific formats and can open only those files.  Same is the problem with Samsung Galaxy Y set and it cannot open 3gp video file because it does not support such kind of formats.
That’s why you received a compatibility error, if you want to play 3gp videos on your Samsung Galaxy Y set you may have to first convert your file into MP3, MP4 or AVI format then you will be able to play these videos on you Samsung Mobile.
Answered By 0 points N/A #186483
Hello Benjamin,
          Sorry to say that, Samsung Galaxy y can't open or play 3gp files because it doesn't support that kind of format. That's why you can't play the file. Samsung Galaxy y only support MP4, MP3, WMV, WAV, ACC formats. If you want to play the file you have to first convert the file into those formats. I hope this information help you.
Answered By 0 points N/A #186488
Hi
I will certainly help to solve your problem with that 3gp file. Your Samsung Galaxy Y phone supports many formats including 3gp. It failed to play in your phone because it would have been recorded with a different video and audio codec. That might be the problem. Record a video with 3gp extension with your phone and try if it's playing.
