Problem with linksys wireless G router
Hi all,
I´ve just got a Linksys wireless G router which has made my life hell since I configured it according to instructions on the net a little while back.
I can usually easily detect a network signal but when I connect using an Acer laptop which uses Vista it will not connect. I tried connecting using a friend’s laptop and that didn´t work either but when I connect using a cable instead of wireless it connects fine, which is no good because I need wireless options.
I have tried rebooting the router and thought I would go back to the factory settings.
After resetting it still won´t connect so I really am stuck now, can anyone help me?
