paul_bd5
Posted on - 09/11/2011
While setting up the administrative access control of my operating system, I have found minimum password age as 1 day, but I need to alter passwords twice or thrice a day. Need proper suggestion from any expert to make such change on administrative level
Policy
Policy setting
Enforced password history
24 password remembered
Maximum password age
60 days
Minimum password age
1 days
Minimum password length
7 characters
Password must meet complexity requirements
Enabled
Store password using reversible encryption
Disabled
Thank you
jemjem
Password duration problem of operating system
If you have not already , you must enable password expiration for each user account that you want to have their password expire after the maximum password age.
Step 1. Open the Local Security Policy editor.
Step 2. In the Left pane, expand Account Policies, and click Password Policy.
Step 3. In the right pane, double click on Maximum password age.(see screenshot above.)
Step 4. Enter how many days between 0 to 999 that you want passwords can be used before the system requires the user to change it, then click on Ok.(see the screenshot below)
Step 5. Finished.
Hello Paul.
Yours is a strange request. Why would you want to change Windows password 2 or 3 times a day?
To me, it seems impractical and, quite honestly, if I were the user constantly being reminded to change my password, I'd be frustrated and pissed off.
I think that is probably the reason why the minimum password lifetime was intentionally designed to have 1 day as minimum.
You will also have to consider what happens to network shares and the current session of the user once his password expires in the middle of an important job.
Good luck on your quest to find the answers to a very challenging idea.
