Network Error (tcp_error) A communication error occurred;””
Hello all,
Even after recharging my internet connection I get this error on opening some websites.
Does anyone know if it is the internet problem or something else?
Thanks for the help.
The web server may be down, too busy, or experiencing other problems preventing it from responding to requests.
You may wish to try again at a later time.
Answered By 0 points N/A #148166
Hi good day,
You can just try this solution. go to your desktop and press the WINDOWS key hold it and press R, Type cmd to open a command prompt try to type the following:
PING www.t-mobile.de
TRACERT www.t-mobile.de
It will show some language, if your ping response like this
Pinging www.t-mobile.de [212.162.148.201] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
TRACERT not found, then probably there might be some issues with your ISP, or else the website or the server for the site is down or not available at a time.
