Private Sub HSVtoRGB(ByRef Red, ByRef Green, ByRef Blue, Hue, Sat, Value)
Dim i As Long
Dim f As Double, p As Double, q As Double, t As Double
If Sat = 0 Then
Red = Value
Green = Value
Blue = Value
Exit Sub
End If
i = Hue 60
Hue = Hue / 60
f = Hue – i
p = Value * (1 – Sat)
q = Value * (1 – Sat * f)
t = Value * (1 – Sat * (1 – f))
Select Case i
Case 0
Red = Value
Green = t
Blue = p
Case 1
Red = q
Green = Value
Blue = p
Case 2
Red = p
Green = Value
Blue = t
Case 3
Red = p
Green = q
Blue = Value
Case 4
Red = t
Green = p
Blue = Value
Case 5
Red = Value
Green = p
Blue = q
End Select
End Sub
'Function RGBtoHSV(Red, Green, Blue, ByRef Hue, ByRef Sat, ByRef Value)
' Dim Temp As Double
' Dim xa As Double
' Dim ya As Double
' Temp = (Red + Green + Blue) / 3
' xa = (Green – Red) / Sqr(2)
' ya = (Blue + Blue – Red – Green) / Sqr(6)
' Hue = Arg(xa, ya) * 180 / pi + 150
' Sat = Arg(Temp, Module(Red – Temp, Green – Temp, Blue – Temp)) * 100 / Atn(Sqr(6))
' Value = Temp / 2.55
' If Sat = 0 Or Value = 0 Then Hue = 0
' If Hue < 0 Then Hue = Hue + 360
' If Hue >= 360 Then Hue = Hue – 360
'End Function
Sub RGBtoHSV(Red, Green, Blue, ByRef Hue, ByRef Sat, ByRef Value)
Dim min As Double, max As Double, delta As Double
If Red <= Green And Red <= Blue Then min = Red
If Green <= Red And Green <= Blue Then min = Green
If Blue <= Red And Blue <= Green Then min = Blue
If Red >= Green And Red >= Blue Then max = Red
If Green >= Red And Green >= Blue Then max = Green
If Blue >= Red And Blue >= Green Then max = Blue
Value = max
delta = max – min
If Not delta = 0 Then
Sat = delta / max
Else
Sat = 0
Hue = 0
Exit Sub
End If
If Red = max Then
Hue = (Green – Blue) / delta
ElseIf Green = max Then
Hue = 2 + (Blue – Red)
Else
Hue = 4 + (Red – Green) / delta
End If
Hue = Hue * 60
End Sub
Private Sub UnRGB(ByVal Color As OLE_COLOR, ByRef r, ByRef g, ByRef b)
r = Color And (Not &HFFFFFF00)
g = (Color And (Not &HFFFF00FF)) &H100&
b = (Color And (Not &HFF00FFFF)) &HFFFF&
End Sub
Function Module(X, Y, z)
' Returns the module of a 3D vector
Module = Sqr(X * X + Y * Y + z * z)
End Function
Function Arg(xa, ya)
'Returns the argument (in radians) of a point in the (x,y) plan
If xa = 0 And ya = 0 Then Arg = 0: Exit Function
If xa = 0 And ya >= 0 Then Arg = pi / 2: Exit Function
If ya = 0 And xa < 0 Then Arg = pi: Exit Function
If xa = 0 And ya < 0 Then Arg = -pi / 2: Exit Function
If xa > 0 Then Arg = Atn(ya / xa): Exit Function
If xa < 0 And ya >= 0 Then Arg = pi – Atn(-ya / xa)
If xa < 0 And ya < 0 Then Arg = -pi + Atn(-ya / -xa)
End Function
Best of Luck
Suominen Ross
