Mc Affee VS Spyhunter 4? Which one is safe
Asked By 45 points N/A Posted on -
Hi guys,
I have windows 8.1 and Mc affee installed in it already as my PC was infected with root kits and other virus my friend suggested me to download spyhunter 4. Now the results you will see is
When I ran a scan via MC Affee the result it showed is 1 GenericPUP.y virus
And when I scan through Spyhunter 4 it showed more than 50 threats.
Please tell me which is good anti virus software. I don't trust spyware as my PC was not infected it was just 2 hours that I got virus while downloading a software from web.
Best Answer by
Answered By points N/A #184184
McAfee isn’t so good antivirus though it offers good support. This isn’t so powerful antivirus. On the other hand, Spyhunter isn’t so reputable protection software. So, I recommend any other antivirus to have on your system.
Norton, Kaspersky, Avira, AVG etc. do quite a great job in protection. They are quite popular, and trusted by their users and have a good reputation in the market. These internet security software protects you from all type of security threats.
Answered By 0 points N/A #184186
Spy Hunter work like an atom bomb on malware, adware and marketing garbage but it struggles against when you have to repair files, defragging and optimizing the disk. But when we talk about McAfee then it`s all in one. It helps you to get rid of malware and also it has extended features of optimizing your computer. It also has a firewall feature.
