Linux software for remote access
I have set up a remote access for my other office. There, the machines run with Linux os. Sometimes they don't correspond to the commands I give. E.g.: exit and shut down. This has over heated the machines as well. is there any Linux software for this?
Best Answer by Sharath Reddy
Answered By 10 points N/A #91164
maybe openssh-server will be an answer. it is secure, fast and reliable. as client you can use default ssh client in linux. you can use putty as client for windows os.
Answered By 0 points N/A #91165
Hey Monica!
You can use VNC to remotely connect to a computer.
Type x0vncserver at the terminal.
You may have to install it if it's not found on your computer.
If it is found, you need to create a folder as /home/name/.vnc/vncpasswd. Type the password in the folder that you want to keep so as to connect .
Then, open terminal and then type x0vncserver -passwordfile /home/name/.vnc/vncpasswd at the terminal. Most probably it will autostart at port 5900.
Then you need to download a VNC client for windows. Most common is tight vnc which I'll recommend. Then, you need to enter the IP address of the computer running linux, followed by the port number and separated with a ":"
For example, 192.168.122.115:5900
Hope this helps.
Cheers!
Answered By 590495 points N/A #91167
Since you are looking for software that can be used for remotely accessing a computer running on Linux, try downloading and installing NoMachine for Linux. You can download it from The Network Computing Company
For Linux – i686
  • NoMachine RPM for Linux – i686 — supports Red Hat Enterprise 4/5/6, SLED 10.x/11.x, SLES 10/11, Open SUSE 10.x/11.x/12.x, Mandriva 2009/2010/2011, Fedora 10/11/12/13/14/15/16/17.
  • NoMachine DEB for Linux – i386 — works on Debian GNU Linux 4.0 Etch/5.0 Lenny/6.0 Squeeze, Ubuntu 8.04 Hardy Heron/8.10 Intrepid Ibex/9.04 Jaunty, Jackalope/9.10 Karmic Koala/10.4 Lucid Lynx/10.10 Maverick Meerkat/11.04 Natty Narwhal/11.10 Oneiric Ocelot/12.04 Precise Pangolin.
  • NoMachine Compressed TAR for Linux – i686 — works on Red Hat Enterprise 4/5/6, SLED 10.x/11.x, SLES 10/11, Open SUSE 10.x/11.x/12.x, Mandriva 2009/2010/2011, Fedora 10/11/12/13/14/15/16/17, Debian GNU Linux 4.0 Etch/5.0 Lenny/6.0 Squeeze, Ubuntu 8.04 Hardy Heron/8.10 Intrepid Ibex/9.04 Jaunty, Jackalope/9.10 Karmic Koala/10.4 Lucid Lynx/10.10 Maverick Meerkat/11.04 Natty Narwhal/11.10 Oneiric Ocelot/12.04 Precise Pangolin.
