Hi I use Internet Explorer for internet browsing. Recently I face script error problem in my Internet Explorer browser. I tried to solve this problem many times but I failed.
"Internet Explorer Script Error
An error has occurred in the script on the page.
Line: 327
Char: 3
Error: Object required
Code: 0
URL:
Do you want to continue running scripts of the page?
Yes No"
Now I am very upset for this problem. Please help me how I can fix this error. Thank you so much.
Hi Sunny21!
To resolve your IE issue, you may delete the browsing history. Here's how:
1. Open an IE browser and look for the TOOLS option which is usually located on the top right corner.
2. Left-click on TOOLS.
3. Scroll down on INTERNET OPTIONS and left click on it.
4. Under GENERAL tab, left-click on DELETE button below BROWSING HISTORY.
5. Make sure that the preserve favorites website, temporary internet files, cookies and history are all in checks and then click on DELETE button. Series of windows will appear showing that its deleting files.
6. Click on OK button after completion.
7. Pull up a new IE browser and check if it resolves the issue. If no go, then try to restore your computer to an earlier time when you still did not have this IE issue by doing the system restore. Follow this link: Start/Programs/Accessories/System Tools/System Restore then follow the prompts carefully. Take note before you do this, you need to save your important files.
1. If you are experiencing this error but you can still view requested page, you only need to disable script debugging. If you are using Internet Explorer 6, go to Tools, select Internet Options, go to Advanced tab, check the “Disable script debugging” box, and at the end click OK.
If you are using newer versions of Internet Explorer (7/8/9), go to Tools (if you don’t see Tools menu, press Alt on your keyboard for displaying the menus), then Internet Options, click Advanced tab, and uncheck “Display a notification about every script error“ box (like on image). After that, click Apply and then OK.
2. Open Internet Explorer. Go to Tools menu (if you don’t see Tools menu, press Alt on your keyboard for displaying the menus), Internet Options and then click on Security tab. Check the Security level – it should be on Default level. If it isn’t, just press the “Default level” button.
