I lost the pc tuner license key.
I lost the PC tuner license key. How can we possibly recover a licensed key from a specific software?
Is there a way to contact some online business firm and ask for some help regarding the software key or validation codes?
Give me some solution to resolve this issue.
Waiting for your support, thank you.
Best Answer by George Stacy
Answered By 0 points N/A #183610
Hi there Christine,
I searched some solution that may help you solve your problem.
This software is a user friendly, all you have to do is to press Find Keys.
You can choose the Authorization Model for recovering certain keys.
Choose “Local Computer” for product keys in local machine.
Choose “IP range” for serial numbers of computers on the network.
Choose “IP Add Listing” license keys.
And after choosing just click OK.
Hope this information helps.
Download it here: http://ptf.com/download/product_key_explorer/0849/
PRODUCT KEY EXPLORER.
Answered By 0 points N/A #183611
Hello Christine,
Losing a product key and finding the correct key may sometimes be so frustrating.
I have personally experienced it and I lost a lot of time finding the correct key.
Anyway I can share with you a website that helps me to find the correct key.
Try to visit https://www.softpile.com/ you can search the correct key in there through their search tab.
I hope this will help you.
