I keep getting Error 1406: I Cannot sequence Adobe Photoshop Elements 4.0
I get an error when I attempt to sequence Adobe Photoshop Elements 4.0. The error would pop up during the setup process. I cannot skip the step to install it. I manually created a registry key to make it work with the setup but it still appears for some reason. Any help on this issue? What should I do to fix this problem?
Adobe Photoshop Elements 4.0 – Setup
Error 1406.Could not write value RegOwner to key
ProductsB1F5E89CB2C51DF4DB9F3F77D9ACAA61Installproperties.
Verify that you have sufficient access to that key, or contact your
support personnel.
Abort Retry Ignore
