How to convert trial software to full?
Hello fellows,
How to convert trial software to full? Yesterday I downloaded a trial software for a specific application and It came up to my mind that is there a possibility for me to convert it in to a full version one? I am just curious about it. In terms of technology well sometimes there are no impossible. I hope you can share with me your ideas.
Thank you.
Best Answer by Julinee James
Answered By 10 points N/A #181559
Trial software is released to present a brief overview of the functions the software can perform. The trial version is a free version that can be tried for free. A person interested in a software can first try the trial version and if he likes it then he can buy the full version of the software. This way the customer will not regret buying the software as he first tries the trial version and is acquainted with the software.
A trial version cannot be directly changed to full version software. A trial version contains only the files needed to perform the basic tasks. The full functionalities of the software are not present in the trial version. So you have to download a separate file for the full version which will contain all the functions and files of the software.
Hope this information helps you.
Answered By 5 points N/A #181560
Trial versions provide you some idea about whether to use the software permanently or not. So use the trail version for some time and then decide about upgrading to the full version.
Upgrading to the full version will always cost you money that’s why the seller provides you a trial version. Trial version always runs only for limited time period. Once the trial period ends you’ll be automatically prompt to buy the license for the software. For the time being you don’t have to bother about upgrading. I’m pretty much sure that almost all the functionalities are available during the trial period except few of those depending on your software.
