nurehasan
Posted on - 08/22/2011
I am using a Microsoft Excel document by using office 2003.
Here, I have three fields (Name, Total Number, Result).
Now I want to use a formula in result field which can be displayed that 40% out of 1000 will Pass and below 40% will Fail.
What can I do to solve this problem?
Formula of result by using a condition.
Suppose you have those figures on your cells and want to have that kind of formatting. Use the formula "If( condition, value_if_true, value_if_false )" and type it on the formula bar. Let's say on your end, your result should be displayed on the C column down.
Based on your figure, go to cell C2 and on the formula bar type the formula "=If( B2>=400, "Pass", "Fail" )".
Since your passing is 40% of 1000 so that is 400 out of 1000.
So, if on the B column (since it is the cell that we are going to evaluate) is greater than or equal to 400 then it would return a value as true, hence the value of "Pass" and if false it returns as "Fail".
Hope this helps.
Thank you
