Recently, I installed PaperPort in my computer and have been working perfectly and enjoyed using it with no issues. However, when I try to download the update for “PaperPort 11” I keep on encountering this error message, "Your current browser Security Setting prevents the proper operation of Update Service. Update Service relies on Active X controls and Active Scripting which are enabled under the default browser security settings". Can somebody help me please? Thank you in advance.
For the application to run, it requires that the activeX controls in the browser be turned off or disabled, and therefore you will need to do that:
If you are using internet explorer to browse, then you will need to use the procedure below to disable the activeX controls in your browser:
Regards
Thompson Locker
