Is any bill pad format blank software is available in market?
Hi.
I am searching for some bill pad format blank software which has features like billing automation, time schedule, employee management etc. It should be web based and can work properly having no processing error and intensive internet security from external attacks. Please suggest any best software.
Best Answer by Michael B Rodgers
Answered By 30 points N/A #131435
Hi Kait,
For bill pad software solution, there is different kinds of software like Advanced Bill of Materials and Mind Pad. It's easy and capable with your all requirements.
For Advanced Bill of Materials you can go to this link:http://www.fileguru.com/Advanced-Bill-Of-Materials/info
For Mind Pad you can go to this link: http://www.filebuzz.com/fileinfo/21279/Mind_Pad.html
For additional info you can click this link:http://www.filebuzz.com/findsoftware/Mind_Bill/1.html
Thanks.hope it works for you.
Answered By 55 points N/A #131437
Hello Kaitlynnnatasha,
If you want to get a web based software then you can get it from the below link. But there if you want any change then you have to pay some money so that they can provide you according to your need. But i think that this can give you what you want.
http://www.filebuzz.com/fileinfo/23733/Online_Pad_Generator.html
Answered By 45 points N/A #131436
Hi Kait,
I believe you are looking for a web based billing and employee management program. If you search the web you would find a variety of such software and you have to choose the best one for you based on their features and options. Among the billing software, Advanced Bill and Mind Pad are quiet popular and user friendly. I have the link from where you can download any of these software.
I hope this meets your requirement.
