No of visitors who read this post: 14324
Category: Software Others
Type: Question
Your rating: None Average: 5 (5 votes)
Hello Experts,
I get this error when trying to export clips that I've cut that are in my timeline in Premiere CS4, which IS activated. The funny thing is that in Premiere, it looks like it works. It's only when I notice, hey, there's a new thing in my taskbar and see this message. However, the clips do NOT export.
AMT Subsystem Error
Thank you for using Adobe Media Encoder CS4. The Adobe product that installed Media Encoder has not activated.
Please launch and activate that Adobe product before continuing to use Media Encoder.
Comment viewing options
# Comment Id: 128902
Hi James
I also encountered this error when I am going to encode the video output o Adobe After Effects to Adobe Media Encoder. Luckily I solved this problem in Adobe Media Encoder. These are the steps that I followed:
  1. Go to: C:\Program Files\Adobe\Adobe Media Encoder CS4
  2. Delete this file: amtlib.dll
  3. Then Go to : C:\Program Files\Adobe\Adobe Premiere Pro CS4
  4. Copy amtlib.dll from there:
  5. Then paste the amtlib.dll to this location: C:\Program Files\Adobe\Adobe Media Encoder CS4
  6. Done! Restart Adobe Media Encoder.
Note: If you use 32-bit versions or version prior to CS6 then choose the correct folders for your case.
I hope this method also fixed your problem in Adobe Media Encoder.
# Comment Id: 150033
To fix this, simply delete the amtlib.dll in your Adobe Media Encoder installation folder located at C:\Program Files\Adobe\Adobe Media Encoder CS4 and then go to the Adobe Premiere Pro installation folder and copy that amtlib.dll from there.
Also, ensure that you have activated your Adobe Premiere Pro copy. Registering is different from activating so you need to make sure that you are done with this process. If the above step didn't work, reinstall Premiere again.
