I got an error while I was downloading my Windows 7 operating system. This is the message:
“Microsoft Visual C++ Runtime Library Runtime Error! Abnormal program termination.”
Attached below is the image so that you will better understand my problem. Please help me. Send me suggestions on how to solve my problem. Thanks!
The Microsoft Visual C++ Library Runtime Error is an error that is usually caused by internal conflicts between programs and applications that you have installed on your computer, and therefore you will need to fix it as follows:
-Clair Charles
