Below are V Gilden's Questions. Did not find what you want
Click here to ask a question of your own
Category: Misc Software
I tried to update Nokia 5800 XpressMusic Software to a beta version (3.3.49). It almost finished but instead gave out an error code 12052. What do you suggest I do? Is the newer beta version better? Appreciate your help very much.
Update Nokia 5800 XpressMusic software
Something’s gone wrong
Category: Hardware
I need to install Belkin Power UPS Management Software on my Windows XP PC, but every time I tried, this message is showing:
Error Message:
Repeatedly Running
There is an instance of setup running, please exit.
OK
What does it mean? I only run the installation once. Help me on this please.
Hello Experts,
I was upgrading my old browser to Internet Explorer 8 but it failed.
I came across to this website, URL http://support.microsoft.com/kb/949220 .  I tried following the easier methods but still the upgrade failed.  Is it better to uninstall the old version?
I am scared to uninstall the old IE version because I might destroy some Windows files.
Please help!
See below the error message I got.
       Reset security setting back to the defaults
