How can I go to windows safe mode ? My computer is infected with virus and I will try to delete it manually using safemode.
- 202 reads
- 2 comments
My pc gets frozen without any reason. I have already run a full directory scan with my regularly updated anti-virus but it is no use. I cannot find any reason behind this. There is plenty of memory left so I am guessing it is not due to load either. Should someone know of this problem kindly inform me about this.
Howel Dinh
- 233 reads
- 2 comments
For my job purpose I have to use multiple browsers at the same time. I have been using it for quite a while now. Recently there has been a problem. Using more browsers at the same time slowing down the PC as well as making it freeze in most cases. Someone help me out of it.
Howel Dinh
- 197 reads
- 2 comments
Hi everybody,
I just compile Trinity core server. After that I try to run my server, but here I got an error message via worldserver.exe. This message is attached below.
I want to get rid of this problem. Any tips?
Is there any possible way to prevent dead pixels on laptop's screen? and how to prevent it from getting bigger?
- 289 reads
- 2 comments
I need to know a easy good video editing software. There are many online software free downloadable but when I download them either they are trial version or they are had to word with. I need an easy software for video editing which will be free as well. Should someone know of any software matching my requirements kindly inform me about it.
Howel Dinh
- 277 reads
- 2 comments
Hi there,
I get an error message when I register an image ( euca-register ubuntu-kernel-bucket5/vmlinuz-2.6.28-11-server.manifest.xml) the error message is like below –
Warning: failed to parse error message from AWS: :1:0: syntax error
EC2ResponseError: 400 Bad Request
Failure: 400 Bad Request
Failed to bind the following fields:
Location = ubuntu-kernel-bucket5/vmlinuz-2.6.28-11-server.manifest.xml
Please help to resolve. Thanks
I installed bootcamp partition on my macbook pro containing a MAC OS Lion windows 7 ultimated, every thing works great except for a two serious problem:
- The right click of the trackpad does not work on windows.
- The device manager shows that all drivers are properly installed but the sound does not work. no sound either through headphones or through speakers.
Thank you for giving a helping hand!
We failed trying to install LD 7.3.1 on Server 2008 R2 in this morning.. We've looked thoroughly through the forum and applied all the tricks but still getting the 2869 error. We are logged in as Admin and running the MSI as Administrator, even tried via elevated command prompt.
Touchpaper Software key is in registry under wow6342node
IIS 6 Mgmt Compatibility is installed
All Roles Services installed as advised
IIS Authentication permissions set as advised
msi run via msiexec /i
AV software switched off
UAC switched off
Installing to default locations
The MSI log files show it fails here (full log attached):
- 618 reads
- 2 comments
