Is there any way to convert file from Microsoft Word to .gif format without using any software converter? If not, I should really get a software converter. The question is where I can get that software? Is there only one software to convert that file or there's a lot of them?
I need to have a permanent password for my laptop, and I want to have a program that the router automatically changes its password daily for my customers.
- 1991 reads
- 2 comments
I am having an Error 1935 while installing OpenOffice. I am running Windows 7. How can I correct the error?
- 437 reads
- 2 comments
I need your help on this problem that arose after I installed Oracle 10g database software on local disk D in my pc that runs on windows 7. The problem is that I get errors telling me permission denied when I tried creating a database. I don’t get this since I enabled “run as administrator privilege” during installation.
What should I do next?
Hi, I am looking for someone to give me an informed opinion on cloud computing for high performance computing applications. What does the future hold for it? The applications I am referring to are the scientific software that usually uses a high processing power. Will there be changes to the alternatives of the programs that are currently on use such as Cyclone, which is not that interesting to use. Thanks in advance for your help
