Windows Explorer restarts after right click
Every time I right click on any file on my computer it gives an error message as below:
Windows Explorer
Windows Explorer has stopped working.
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is
available.
Close program
Then it forces to close the Explorer. The new Windows Explorer starts automatically. It does not affect any running application.
