Will swf file play in cd player?
Hello guys,
Will swf file play in cd player? When I am going to burn a swf file in a cd player is there a way that it will still play and I want to know a software that supports this kind of problem for me to be able to perform this tasks. For additional information i am using windows xp operating system. I hope you will help me with these experts, I am looking forward for a solution. Thank you
Best Answer by Johnstoon Leen
Answered By 0 points N/A #173168
Some swf files look for their domain before running. You first have to check that whether your swf file require domain to run or they are independent of domain. Some players are programmed with flash player and they can directly run swf files. Unfortunately, most players are unable to run them unless they are programmed to do so.
Answered By 0 points N/A #173169
Hi Virginia Adams
Well there is a simple and easy solution for you,
You have to follow these steps below
Make a text document and save it as “autorun.inf”
And now write this file on CD.
Your content will look like this
[autorun]
open = yourappname.exe
icon = youriconname.ico
You have to put icon on CD; it’ll show up instead of default icon your CD.
The most important thing which you need to follow that always uses small letters in .INF file.
Now burn your .swf files into CD player, it’ll definitely works for you. Good Luck!
Johnstoon Leen
