Where can I get a data entry form template using HTML?
Hi. I need to have a data entry form template using HTML for my website. Preferably, the form should have the capacity to accept user inputs. Can you tell me what site should I visit so that I could pick styles and layout for my forms? What other alternatives should I consider aside from buying templates in the internet? Thanks.
