Weird files on flash memory disk, cannot be deleted
I have a Sony Micro Vault USB, like this one described on this site
and I found some weird files on it, all in a directory marked as "Read-only" and I can't delete/modify any file and the directory is locked.
The files are extension less, with huge sizes (about 50GB) while my flash drive is only 32GB.
I want to remove these files but failed, I can't format it, not even using the command-prompt.
Any suggestions ?
Thanks
